LOMO Reisemikroskop, LED
Begonnen von Rene, März 31, 2017, 10:23:03 VORMITTAG
Rene
Hi guys, I have one of those LOMO's in Blech-container, which I want to take with me on holidays:
This is a similar from an earlier posting on the forum:
(from http://www.mikroskopie.de/mikforum/read.php?4,33257)
Before having to invent the wheel again, can someone suggest an easy LED adaptation, or has somebody something useful straight away?
Thanks,
René
Hi Rene´,
I use any of them, with a selfmade LED-Light. It works up to the 40x Objective and makes "kritische Beleuchtung". Very nice for the lower magnification. You can use it with 9V Block-Batterie or =~15V NT.
I see only one problem. The hole in the base has the big diameter of the old Microscopes. The new Type, I use, is smaller!
If you are interestet, I can send picturs oft the "lowcost" version (real plastic 20€) or "deLuxe" (aluminium 50€)
regards
Hugo Halfmann
Hallo Wolfgang,
bitte zeig doch mal deine beiden LED Lösungen!
Hugo Halfmann
Hallo Hugo,
die Plastikteile waren ein Versuch und sind alle weg. Das gute Stück in Alu sieht so aus:
