Styrodur(R) and Eldermarrow (holundermark) - a comparisson
Begonnen von Klaus Yde, November 19, 2008, 14:41:59 NACHMITTAGS
Klaus Yde
With the help of two member of the forum I have just got several years suply of Styrodur and some eldermarrow. In Denmark Styrodur is not as easy to get as in Germany, but when I contacted the Danish representive via http://www.styrodur.com i just got a plate (50 x 50 x 5 cm) for free. That is service!
Styrodurplate:
Just for fun i made two thin cuts with my table microtome and got a surprice. They were nearly identical in structure, pore size and color. I took a set of pictures through my stereomicroscope with the same magnification and a picture of my micrometer slide to make a bar.
The results can be seen her:
Styrodur:
Eldermarrow
MvG Klaus Yde
Hallo Klaus
sag ich doch die ganze Zeit ;D ;D
Viele Grüsse
und gut Schnitt
Willy
Hi Klaus
if you make a cut from Styropor ( EPS ) then you have a 3rd Picture with the same structure ;)
Klaus Yde
Hi Both
Sounds interesting - but why this old thread has been opened after 5 years I am not sure that I understand?
Kind regards
Klaus Yde
das liegt an Kislogoisla der alle alten Threads mit einem mehr oder weniger intelligenten Kommentar wieder aus der Versenkung holt. Er kommt mir ein weinig wie ein Troll vor.
Vorgestellt hat er sich bisher noch nicht.
Willy
