Background Subtraction Toolkit - problem
Begonnen von Klaus Yde, November 02, 2009, 16:55:35 NACHMITTAGS
Klaus Yde
I have used this little programs for several years without any problem. But suddenly it wont work any more. I can start it and make subtraction but when I try to save the results I get zero size files. I have reinstalled it and updated my Java and downloaded a new copy - all without any luck.
Searched the Internet - no results.
Has anyone had the same problen and got it solved? Or know another prgram that can do the job.
I use Vista 64 - installed it on an older XP - same result
Yours sincerely
Klaus yde
Hello Klaus
I haven't used the BST for ages, so I can't say anything regarding your problem. But I can recommend "fitswork"
http://freenet-homepage.de/JDierks/softw.htm
It works fine!!
Otherwise there are photoshop tricks, if you have it I can explain..
So long
P.S I don't remember wether you read german??
Klaus Yde
Thanks - I read and speak German fluently (best in the summer where I very often sails in the waters of Rügen) - but my written German is very slowwww.
I have just found Background Remover: http://www.software.com/background-remover-3.0-photoshop-plug-in-9524-1  - It seems interesting - but I havent tested it yet.
I would be very glad if You had some links to Photoshop Tricks -  I have Photoshop Elements 7.
MvG Klaus
