what is it??
Begonnen von arturoag75, Januar 09, 2012, 14:01:30 NACHMITTAGS
arturoag75
Hi,
i think this is a Tecamoeba but i did not seen one before!
can you tell me what is it?
objective 40x Phase contrast - Flash
many thanks
arturo
Lieber Arturo,
es könnte eine Arcella sp. sein, vermutlich als Schwebeform wegen der vielen dünnen Axopodien. Eine Aufnahme, in der die Schale besser zu erkennen ist wäre sehr hilfreich.
arturoag75
many thanks
may be a Gromia??? ???
best
arturo
Martin Schneider
Hallo Arturo,
Ja, ich denke es geht in diese Richtung, Arcella ganz sicher nicht wegen der retikulosen Pseudopodien.
Allerdings kennt sich Ferry gerade mit diesen "weichen" Schalenamöben besser aus.
Kannst Du die ungefähre Größe nennen?
Ferry
Hi Arturo,
You have beautiful pictures as usual, but it is impossible to tell you what kind of amoeba this is without a good picture of the shell or body. It is not a Gromia: these amoebae do have granules on their filopodia. Without further information I guess it could be a Lecythium, Plagiophrys or Chlamydophrys species. Compare yours with:
Plagiophrys scutiformis
Lecythium
Ferry
www.arcella.nl
www.natuurfotografie.info
Servus Arturo,
I think it's important to know where this species was found. I guess it is a Lecythium, but I'm not a specialist.  ;)
Kind regards
arturoag75
Hi Ferry ,
i think your last pic (dic one) is similar what i see..
i add two more pics i hope help you more..
Angie : many thanks for your answer  :D
arturoag75
Zitat von: Monsti in Januar 11, 2012, 21:56:47 NACHMITTAGS
Servus Arturo,
Kind regards
....oops i forgot to tell you , i found this in a colture whit a lot of Closterium algae and rotifergen.Lepadella!
best
arturo
Ferry
Hello Arturo,
Yes, those last pictures make sense, because I recognize the vacuoles at the base of the network. I guess it is Chlamydophrys stercorea; based on several observations I think that Chlamydophrys stercorea is a Lecythium species. Lecythium species are very common, still we don't know much about their taxonomy.
Thanks for the photos!
Ferry
www.arcella.nl
arturoag75
