Autor Thema: mU scale for adding a size scale in micro photo’s  (Gelesen 345 mal)
deBult
« am: August 22, 2020, 14:45:48 Nachmittag »
Step by step I’m trying to improve my skill in taking microscope pictures.
Now I want to add a mU scale for size to the pictures.
I read several threads in the past on software that helps you do this.
As I do not recollect the correct terminology in the German language the search facility in the forum is not of much use.
Please help me out and refer me to the correct thread and/or search terms to use in German language please,
Thank you,
Maarten
Olympus BH2 with SPlan Apo & Achro mix and several condensers, CH2 with Dplan & Achro-phaco, an Oly HSC mono for travel.
The correct number of scopes to own is N+1 (Where n is the number currently owned)
Florian D.
Re: mU scale for adding a size scale in micro photo’s
« Antwort #1 am: August 22, 2020, 15:38:19 Nachmittag »
Hi,
Bastian has a nice introduction on his own page:
https://archaeometallurgie.de/mikrophotographien-und-massstab/
Kind regards,
deBult
« Antwort #2 am: August 22, 2020, 15:45:18 Nachmittag »
Thank you: will have to find a PC as his pages are not compatible with iPad.
Bastian
    • Analyse archäologischer Gegenstände
« Antwort #3 am: August 22, 2020, 15:52:59 Nachmittag »
That does surprise me a lot! Can Ipads not even handle validated html code anymore? Any browser should be able..
Bastian
deBult
« Antwort #4 am: August 22, 2020, 16:13:14 Nachmittag »
Most of the pages work: the one referred to is one flikkering screen with fast opening and re-sizing windows
« Letzte Änderung: August 22, 2020, 16:15:05 Nachmittag von deBult »
Bastian
« Antwort #5 am: August 22, 2020, 17:04:30 Nachmittag »
Interesting, there it is a completely static page. I just re-checked, if  anything had gone awry there. But, no there is nothing wrong with the html code.
Basically what you have to do, is to take a picture of your lenicules with all your lenses. Then you work out mathematically how many pixels reprsent a micrometer, and then you can calculate the length of your scalebar  and add it to your pictures.
I wrote a script to automate this, if you know the width of the section you see under the micrsocope. should run un OSX, too, I guess, with a few tweaks...
Bastian
« Letzte Änderung: August 22, 2020, 17:18:01 Nachmittag von Bastian »
deBult
« Antwort #6 am: August 22, 2020, 19:12:20 Nachmittag »
Well the page is opening OK on a iPhone though.
deBult
« Antwort #7 am: August 22, 2020, 19:21:48 Nachmittag »
Started the measurements with my micrometer slide.
If I remember correctly one of the forum members has a Developed a stacking program with the functionality to incorporate a scale bar ?
Update found it: Picolay
Tnx, Maarten
« Letzte Änderung: August 22, 2020, 19:26:44 Nachmittag von deBult »
