Hallo to all, can someone more chemically minded give me an answer:
Iodine (I2) does not dissolve well in water, but mixed with iodide I- it forms [I3]-
Standard protocols dissolve 5g iodide + 10g potassium iodide (KI) in 100 ml water (originally: dissolve to 85ml solution, in order to get 150mg iodine per ml). To that mixture I add 10 ml acetic acid for the standard marine preservative, which is used in the conc of 4ml lugol per 1 liter sample.
Now generally not all iodine dissolves in the stock solution, also, after a year or two I regularly come across small deposits of (I think) iodine in my samples.
I wonder whether I am adding enough potassium iodide. Mol for mol, there seems enough KI to dissolve the iodine (5g I2 per 100ml is 0.2M, 10 g KI per 100ml gives a 0.6M solution). Is there some equilibrium so that I need to add more KI? Or could it be an effect of the addition of acetic acid?
Many thanks,
René
