Schnitter Advice Needed: Junk hand cylinder microtome...
Begonnen von Michael Cytrynowicz, Juli 01, 2024, 11:37:03 VORMITTAG
Michael Cytrynowicz
Dear Microscopists,
(and I hope in a few months I can carefully start posting in German :-)
My old Jung hand microtome, the cylinder type, is playing tricks on me.
The screw movement seems to have a bit of looseness and recoil.
If I turn the base wheel 360-degrees counterclock-wise (that is, 50x 10 µm intervals) it will (as measured by a caliper) correctly go up by about a ½ mm.
But rotating the base say just 5 units, which I would like to be able to do in order to obtain good 50 µm botanical sections, this doesn't seem to be precise at all.
What usually happens is the first 2 or 3, 10 µm intervals, the microtome's inner cylinder doesn't seem to move up at all. I can feel it in my fingers that the movement seems "not engaged".
Then I turn one or more ticks, and often the movement engages again.
This does not happen extremely consistently, though, so it is a guess game.
Right now, I only seem to be able to consistently get cuts that are 100, or 120 µm thick - and I do that by rotating 10-12 intervals straight. Any less intervals is completely imprecise.
Any ideas?
Thank You from Porto!
Mike
Zeiss Standard (Hybrid). Canon 80D / Pentax-M 40mm / RAF  adapters / Zeiss Halbkugel / Siedentopf Trino & Photo port / KPL W 12.5x Br / Optovar 0.8-1.6 / Zeiss Planapo 4/0.16 / Planapo 10/0.32 / Planapo 25/0.65 / Neofluar PH2 40/0.75 / Olympus SPlan 40/0.7 / Condenser  II z  / Stephan Hiller LED
Michael Cytrynowicz
Oops I noticed I typed "Junk" - instead of "Jung". This was NOT intentional, but a big Freudian Slip :-(
Mike
Did you unscrew it completely and checked the thread for damage? And wash off the old grease with petroleum ether and replace it with fresh one.
Regards
Michael Cytrynowicz
Thank you Martin - how do I take the bottom out to expose the screw?
Also, would you know what the 2 little holes in the inner cylinder are?
Thank you!
Mike
Hello Mike,
ZitatOops I noticed I typed "Junk" - instead of "Jung". This was NOT intentional, but a big Freudian Slip :-(
thats quite a joke  :-)
remember: "The syringe is your wife, till the rest of your life".
best regards
Wolfgang (not on turkey)
Well, this looks different as I had expected (below a picture of the device as I know it). You have disassambled it completely. Where is the lower part with the microthread?
I don't know the function of these holes. Sometimes holes are only a an outlet for air when compressed.
Michael Cytrynowicz
Ah! Martin - thank you. I figured out the base was just removed by continuing to unscrew it all the way. Today I fell not especially smart.
Anyways, mine looks a much older version than yours, my father gave it to me in 1967-68 I think.
Here are the photos of it completely disassembled, and showing the entire screw. Does not seem to be damaged, but someone smarter than me can readily tell what's wrong :-)
Schönen Dank!
Mike
Michael Cytrynowicz
I remembered a case where the doctors forgot a syringe inside the patient's body ;-)
Not on turkey? Hm, Ich habe das nicht verstehen...
Zitat von: liftboy in Juli 01, 2024, 13:35:11 NACHMITTAGSHello Mike,
best regards
Michael Cytrynowicz
...und nur die Bildungen  (hope my German is ok?)
Grüß
Michael Cytrynowicz
if no damage visible, maybe cleaning and re-lubricating will do the job...
Michael Cytrynowicz
Thank you Martin - I don't have Wundbenzin, but I do have
Special Blade Degreaser (bought years ago)
WD40
Xylol
what is best?
and for re-greasing, Teflon Nye (grease better than oil, correct?)
Grüß aus Porto
Mike
for cleaning puposes any grease solvent will do. As for relubrication I hope that other experienced users will answer...
Aljoscha
Hi Mike,
To clean the stuff, isopropanol or any other alcohol will do the job.
Avoid oil, high viscosity grease is a much better option.
Best regards
Alexander
Michael Cytrynowicz
Thank you dear Alexander and Martin! - I have both the Isopropanol and the high-viscosity grease here with me.
I will do it and report back soon. Excited to get my microtome working finely again!
Best Regards,
Mike
