Centering a Zeiss circular stage
Begonnen von tlansing, März 24, 2024, 22:56:56 NACHMITTAGS
tlansing
Hello Forum,
I have an old Zeiss circular stage (first photo) and would like to center it.  I know that there are two centering screws (arrows in the second photo) that are used in the centering procedure.  I would greatly appreciate advice on how to do this.  Thanks in advance for your help!
Tim
Hi Tim,
is it that you just need the srew drivers or do you ask about the procedure how to do the centering properly?
Michael Müller
Hi Tim,
enclosed a page from the Zeiss-manual...
Best regards
Gerne per Du
tlansing
Hi Jürgen and Michael,
@Jürgen: I am looking for the procedure and would appreciate any advice/guidance on the procedure.  I have one of the wrenches.
@Michael:  Thanks for the reference from the manual.
Best wishes,
Tim
Hi Tim,
first a whole bunch of ifs: If you happen to be in the possession of the dedictated centering slide of your circular stage things are quite easy, if nobody of the pre-owners has disassembled stage and stage carrier. Then you just put the centering slide on the stage and transfere the readings usually hand-written on the slide to the cross guide of the stage. Then the cross of the slide is in center, you just have to align it with a cross hair eyepiece via the centering srews.
If you are not that lucky things are just a little fiddly. Use a slide with a small black point of high contrast - this may be a cross line slide or a micrometer slide- an bring it to the center of the field of view using a 10x or 16x objective. Then turn the table and that point usually will turn around in a circle the center of which is the center of the optical axis. Then you move your reference point to the middle between its original position and this center point by means of the stage´s centering srews. You will have to re-do this several times, but, eventually, you will hit the goal.
Good luck!
tlansing
Hi Jürgen,
Thanks for your rapid reply.  Unfortunately, I have option #2.  I will follow your instructions and hopefully will have success.
Best wishes,
Tim
Hi Tim,
I think, at first you have to remove the top of the table. Turn the the centeringscrews out, till you can move the tabel. Than remove the desk to clean the lower side. As next you have to clean  the springbolt, give him a little grease und bring it in a proper position. Than you can replace the table. Don´t use the knobs of the crosstable meanwile adjusting!  Now (at best) you remove the okular out of the tube and one of the objectives. Meanwile you look thru the tube and the empty hole of the revolver, you can bring the tablehole in the middle of the field of sight. Maybe you must close the diaphragmen. Now you have to replace tube and objektive, put a slide  marked with a colorpoint on the table. Bring the point in the middle of field of sight, an then turn the table and look, in wich direction the point move. If he moves out of sight, you must turn the centeringscrews to bring it in the middle. Then you must turn the table 90° and see, how the point moves. This pocedure must be made so often , til the point remains in the middle. Don´t forget to mark the scalenumbers of the table! Below some about Lomo, seems the same :-)
regards
http://www.mikroskopfreunde-nordhessen.de/dateien/Kreuzdrehz.pdf
Hallo Wolfgang,
von der Notwendigkeit, den Tisch zerlegen zu müssen, war aber nicht die Rede!
aber besser ist das :-)
Meistens ist der Gegenbolzen mit der Feder verharzt; wenn man dann die Stelschrauben zu weit reingedreht hat und sie dann wieder herausdreht, ist der Tisch lose. Bevor ich mich dauernd ärger, mach ich´s gleich richtig.
PiusX
Liebe Mikroskopiker,
bei dieser Gelegenheit hänge ich im Zusammenhang mit dem hier im Thread angesprochenen drehzentrierbaren Kreuztisch noch einige Fragen an:
Für welche Untersuchungen wird er vorteilhafterweise eingesetzt bzw. in welchen Fällen wird die zusätzlich zu der üblichen Kreuztischbewegbarkeit vorhandene hochgenaue Drehwinkeleinstellung benötigt?
Kann der drehzentrierbare Kreuztisch aufgrund seiner umfangreichen Verstellbarkeiten gegebenfalls bei der Polmikroskopie auch den dafür eigentlich vorgesehenen Drehtisch ersetzen, vorausgesetzt daß ersterer entsprechend einjustiert und gewartet ist?
Hat jemand von Euch es realisieren können bzw. realisiert, Polmikroskopie mit dem drehzentrierbaren Kreuztisch statt mit dem eigentlich für die Polmikroskopie vorgesehenen Drehtisch über einen längeren Zeitraum zu betreiben?
Netten Gruß
PiusX
Hallo Pius,
genau das Thema hatten wir mal bei einem Treffen :-) Ein Mikrofreund war dann so nett und hat alte CD´s mit einer 360° Skalierung versehen; zwei Löcher für die Klammern oder den Objektführer und fertig. Ich hab noch eine, könnt ich Dir abtreten :-)
